I have had my Vaio Laptop, model PCG-8161M for 2 years now and have tried many different methods of overcoming my problem without success. Hopefully, someone on here will know a cure.
When I hover over any button intentionally or unintentionally, the button is selected. This has caused major problems by deleting e-mails, sending unfinished e-mails, drawing unwanted lines, deleting text etc etc.
I cannot find a cure in Windows, I even upgraded to windows 7 in the hope of a cure, there is nothing in control panel that I can see.
All I want to do is switch this off so I have to physically click to press the button.
Anyone help, pleeeeaaaase
Solved! Go to Solution.
Are you using Single Click mode? This "feature" seems to be inbuilt with that mode. Either change to 'Double-Click to Open' mode (Control Panel -> Folder Options -> General Tab) or if that does not work or you are already in double-click mode a small Registry edit should fix it: -
Windows Key -> R -> REGEDIT
Go to:
HKEY_CURRENT_USER / Control Panel / Mouse
Then:
Set 'MouseHoverWidth' and 'MouseHoverHeight' to 0.
Go to:
Then:
The double click was already set as you describe, the REGEDIT seems to have done the trick but I will give it a week to check all programmes. Many thanks for your help.:smileyhappy:
Unfortunately, the problem still exists. Now I have altered the REGEDIT, I can no longer double click to select anything. This does not apply in all programmes though.
Any other suggestions would be welcome so I can try them.
Message was edited by: alakemp5
Try setting each (MouseHoverWidth and MoususeHoverHeight) to 1 (this is the number of pixels used for folder or program selection). If it's set to 0 no pixels are used hence your problem.
