A6000. Problems with display screen going off and on. like lose connection.
Brian-XTKD
New
Camera is in excellent condition never been knocked or damaged but display can be quite annoying.
ALSO when transfering photos to phone via wifi it is hard to keep connection.
edited[personal details removed]
4 REPLIES 4
danardeng
Contributor
This detail is really important: can you tell if the wifi stability is the same or is got worst in coincidence with LCD issue?
This is the meaning: if the wifi stability is the same than before the LCD start to has this issue, than 99% is a problem of internal wiring of LCD. The fixing can be cheap.
But if the wifi stability is got worst with LCD issue, it can be a bad signal that the main board have a problem. The fixing cost can be way more expensive.
Anyway, it's an hardware problem that only sony's operators can fix. You should contact them. https://services.sony.co.uk/supportmvc/en/BookService/Disclaimer?cat=Camera&parameter=OTHER
Brian-XTKD
New
EVEN WHEN TAKING PHOTOS THE DISPLAY SCREEN STILL TURNS OFF.
danardeng
Contributor
This can't answer to my question
EMS_MO72
