A6000 Wireless Flash
Petedox
Explorer
Hi, I've just got my A6000, and I'm very pleased with it! I've retained my A350 and was hoping to use my existing HVL-42am flash via the wireless connection.
However, on the A6000 menu the Wireless Flash option is permanently greyed out - when I try to select it says 'This function is currently disabled'. Can anyone shed any light on this?
3 REPLIES 3
Bieomax
Member
are you using an adaptor to connect it to the camera ?
Petedox
Explorer
Hi Bieomax, no I'm not using an adaptor, I thought the adaptor would only be required if I was trying to attach the HVL-42 directly to the camera body.
So, if I'm operating the flash remotely does the adaptor tell the camera to wirelessly fire the remote flash (and presumably 'ungrey' the setting in the cameras menu)? None of this is clear in the manual!
Bieomax
Member
I think you need to mount the flash first to pair it up to the camera to use in wireless mode
