Blackout on High FRame Shooting - Sony A7RV
SOLVED
KeithMark1
Explorer
I maybe being a little slow or daft but can someone point me in the idrction of how you remove the blackout when shooting in high frame on the A7RV please?
Have it set on my A9i but for some reason i cant seem to figure it out on the A7.
Thanks
1 ACCEPTED SOLUTION
Accepted Solutions
danardeng
Contributor
You should remove your mechanical shutter 🫣😅
9 REPLIES 9
danardeng
Contributor
KeithMark1
Explorer
How stupid do I feel!! Thanks 😊
danardeng
Contributor
I was joking. The use of the fully electronic shutter on the A7RV is highly not recommended.
So you can’t eliminate blackout on A7Rv
KeithMark1
Explorer
That’s a shame as on the A9 I don’t get that issue..
danardeng
Contributor
🤣 are you serious?
KeithMark1
Explorer
See now I don’t know if you are joking or not but yep I don’t have that problem when shooting continuous on the A9
danardeng
Contributor
Only A9, A9m2, and A1 are blackout-free, thanks to his stacked sensor that don't need for mechanical shutter.
On all other cameras you need for at least front curtain shutter, ant it introduce a blackout.
If you use full electronic shutter on your A7Rv to get out the blackout, you'll meet a lot of issue in most common situation (banding, "jelly" effect, etc)
danardeng
Contributor
