DCR-HC14E Not Recognised by PC
Methven
New
Hi,
I have a DCR-HC14E Handy Cam circa 2004 and about 40 Mini DV cassettes full of family memories.
I am struggling to connect the DCR-HC14E  to my PC.
When I use the USB to Fire Wire connection I get the following pop up on my computer screen:
'USB device not recognised - The last USB device you connected to this computer malfunctioned and Windows does not recognise it.'
It is a brand new cable so should be no problem.
I wonder if it is because I'm using Windows 11 or possibly there's a hardware issue and I need to buy a more modern camcorder to transfer the cassettes?
Many thanks for any advice as I'm at the end of my tether.
Thanks
2 REPLIES 2
profile.country.IT.title
Marino.Manolo
No FireWire to USB Adapter will work (same if you have a Cable, which shouldn't even exist).
You need a PC with FireWire Input or an External USB Video Capture Card.
Methven
New
Many thanks - I'll give that a try.
