Hi,
I have a Sony Vaio, about 5 years old. Ram is inadequate. Is it possible to upgrade the Ram from 512MB to 1 or 2 GB.
I cannot see a model name, but it has the following numbers:
Serial/Model No XXXXXXXX XXXXXXX and
SN No. 00045 454 157 393
I would be grateful if someone can answer the above question and if that is possible, can you list a site where memory modules can be purchased??
john.jgcork
Message was edited by: Blencogo
We need the model to see what the maximum RAM you can use is.
You should find it on the screen surround - it will probably start VGN-
