How to buy Dragon software?
SOLVED
Hi All,
I had to chose between a digital recorder with a microphone or one with the Dragon software. I bought the one with microphone. so now, I would like to buy the s/w, but can't see it as a separate item.
Any ideas?
Many thanks for any answers.
Tags (1)
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
Hi There
Amazon has these.  Search for either "Dragon Dictate" or "Dragon Naturally Speaking".  A new version is apparently due out this month (very soon) - Version 13.
5 REPLIES 5
Anonymous
Not applicable
Hi There
Thank you Quinnicus!
Anonymous
Not applicable
Your welcome.
Have fun!
Thalamus.
Champion
Hi Martin-abc,
welcome to the Sony User Community Forum..:smileyhappy:
You may not be aware but the Dragon Naturally Speaking Recorder Edition software that is supplied with digital recorders is usually a stripped down & limited version of Dragon Naturally Speaking, one of the limitations is that the software will only recognize, & convert it into a text file, an audio file that contains your recorded voice, so depending on what you are planning to record it was probably a sensible choice to purchase the fully featured Dragon Naturally Speaking software at a later date..:smileywink:
Thank you!
