Vintage WM-D6C Professional Recorder
SOLVED
Mandoist
New
1. I bought my WM-D6C Professional Recorder new in the 1980s in the USA.
2. I now live in the Netherlands.
3. The unit has a DC power input of 6V.
Question: Is it safe to use a European 6V power adapter?
1 ACCEPTED SOLUTION
Accepted Solutions
Thalamus.
Champion
Hi Mandoist,
welcome to the Sony User Community Forum..:smileyhappy:
In addition to the post above it may be easier to use batteries, or possibly rechargeable ones, instead of searching for a replacement or compatible power adaptor..
but if the adaptor is the route you want to take then the following chart below may be of use..
2 REPLIES 2
Anonymous
Not applicable
Hi there
I have done a little googling on this, the common issue seems to be the polarity of the adapters.  Have a read of:
http://www.tapeheads.net/showthread.php?t=10470
http://www.vintage-radio.net/forum/showthread.php?t=72067
It is for the UK adapters, but could possibly be the same for the Netherlands too.
Thalamus.
Champion
Hi Mandoist,
