Hello,
What kind of headphones do I have to buy to my Sony Xperia 1?
Is Bluetooth the only alternative? Do you have suggestion for a cheap kind of headphones that works good?
Thanks a lot in advance and kind regards Fredrik
Solved! Go to Solution.
hello @fredriksolborg
you can choose from the wide array of products sony has here: https://www.sony.co.uk/electronics/headphones/t/headband-headphones
there is also an optional accessory that you can buy so you can use your wired headsets: https://www.sony.co.uk/electronics/accessories/ec270
Thanks very much for the answer!
It really helped me
Best regards Fredrik
