Xperia 1 vi lag
profile.country.GR.title
GeorgeElefthe
Explorer
Xperia 1 vi lag
Hello. I ve just received my xperia 1 vi and it is very laggy especially when scrolling and opening folders.I have done factory restore 2 times and software repair, updated everything but the problem remains...Is it a known issue? Should i wait for a software update. I m coming from xperia 1 iv and v and no issues there.
Tags (5)
14 REPLIES 14
GeorgeElefthe
Explorer
I have noticed that the lag appears when the screen throttles from 15 to 120Hz. When it's on 120Hz it runs smoothly everywhere. The issue persists in safe mode all the time because (i think) it's running at a lower refresh rate there
profile.country.CZ.title
Damian87
Member
Hi, I noticed same thing. It is lagging while changing refresh rate. It is really annoying.
GeorgeElefthe
Explorer
Yes it is... Are you going to return it and get a replacement or wait for a firmware update?
Damian87
Member
Hi,
I'm thinking of returning it and change on something different actually,
but not only because of this Lag situation. In general I dont see much
improvement over my previous 1 V. I had hope that system will be more
smooth and animations better, camera disappointing at the moment, specially
during darker conditions. Also ultra-wide is bad. What is great is battery
life, new form factor but thats it so far.
Damian87
Member
Can we actually report it to Sony ? or at least ask if Sony is aware of this issue somewhere ?
GeorgeElefthe
Explorer
I have send an email directly to Sony, opened a ticket via Sony's support app asked on XDA forum and posted on reddit too..   https://www.reddit.com/r/SonyXperia/s/VSqDdSDzK3
So far they replied with the usual ( factory reset, phone reset etc. ). I m still in discussion with the support here in my country. I m trying too see if they going to fix this with an update because it's a very obvious bug, also reported from too many people.
GeorgeElefthe
Explorer
At the moment I m adding all the apps that I want to use without any lag inside Game Enhancer app and locking them at 120hz. That way they are running at 120 all the time and no lag appears.
Anonymous
Not applicable
@damian87 Did you try the basic troubleshooting steps? Does it make any improvements?
profile.country.NO.title
Fury5d
Explorer
It maybe not the phone that is lagy it could be the you network check the signal if if you are on 5 G switch of 5G and try 4G has much better coverage then 5 G try that . When you are in a area where is bad signal the phone will always try too find the signal and that drains the battery and can make the phone lagy try 4G that should work if not may wait for the next update . Hope that helps you.
