Xperia 5 , bad performance bad battery life
cccbadr
I want to thank the Sony updates team for its recent efforts, really the latest update is a disaster on the performance and battery of the phone , congratulation and weight in performance, battery is running out quickly, really the phone has become I do not like and I want to improve the performance of the phone and the battery also thank you for your efforts
profile.country.NL.title
Strampke
I assume your post has a cynical undertone?
After an update the software has to settle.
The software learns from your behaviour and adapts with the intention to maximize battery life.
Advise:
Restart your device by pushing the power button and volume down button simultaneously.
Hold it for 2 minutes and ignore the conditions every now and then.
Restart if it doesn't restart by itself and wait a day or two before making a judgement.
Come back and share your experiences.
Hope this helps you enjoy your device as before.
Preytheon
Normally on Android devices you can see which application is draining the battery - it may be that one of your apps isn't 100% compatible with the latest update and is causing a drain (or maybe it just needs to be uninstalled and re-installed).
I can get to the menu via Settings - Battery, then looking for the three dots in the top right and select "Battery Usage". Stats will be unavailable until there is ~10% battery drain since the last time it was charging...
