I updated my mac system to OS X 10.8 and now the Image Data converter ver.4 does not work anymore. It does not support the new system and I cannot find update for the ID converter. Is there another way/program to convert the sony ARW raw files( I have the NEX-7)? Or is there an update coming soon?
Solved! Go to Solution.
Hi miikka, welcome to the Sony Forums
Have you tried iPhoto? Bundled with the Mac OS; should be in your Applications folder.
Pretty sure it'll open ARWs. If not you can use Image Capture (also in there) to get them off the card, convert with Adobe DNG Converter (no quality loss) and import into iPhoto that way.
Mick
Mick
hi,
Thanks. That works! I didn't expect iPhoto to be able to read the ARW file but that's great.
Great
glad it worked out for you.
Mick
Have you tried the new version 4.1 yet?
http://www.sony.co.uk/support/en/product/DSC-RX100/downloads/SW_IMAGE_DATA_CONVERTER_V41_MAC
I have Windows so iPhoto no good. Also tried Adobe DNG converter and that does not work for the RX100M6
Hi @Sheila.Haycox,
so, which software do you use?
In case it's e.g. Lightroom or PS I'm afraid that you've got to wait a couple of days (weeks?). Adobe's "Camera Raw" is currently supporting the RX100 series up to version M5 only. As the M6 is rather new they obviously didn't manage to add it to their June update.
Well, some July days still left so there might be a chance that the M6 will be incorporated into the next update. But please, don't make me responsible in case they're not managing it. This was just a look into a foggy glass ball...
darkframe
I am just impatient and realise Adobe will eventually update their Raw but you would think thatif a firm is supplying gear that hs raw files would also produce a raw converter to dng
