Hi mates
I'm having trouble with shutter shadow when using HSS (High-Speed Sync) off-camera flash with my Sony a7M4, Godox XPro-S, and Godox V860II flash. Electronic shutter is off. Strangely, I don't have this problem with my Sony a6400 using the same setup. Has anyone else experienced this, and if so, what solutions did you find? After the firmware update 4.0 it's started
@Jomonjoseph Have you tried to adjust the flash sync speed? like in this article: https://helpguide.sony.net/ilc/2110/v1/en/contents/TP1000759509.html?search=flash%20sync
