I have a Sony A7R V camera. I've switched from PAL to NTSC and I'm using XAVC S HD format and a CFexpress card, however the slowest frame rate showing in the menu is 60p - 120p does not appear.
Any idea if I can change this? Sony says the Sony A7R V will film in 120p when set to NTSC and using XAVC S HD and yet it's still not appearing as an option.
Hello @ntanzabel,
is it maybe only available in the "S&Q" part of the settings?
https://helpguide.sony.net/ilc/2230/v1/en/contents/TP0002920000.html
- Nic
Unfortunately, it's the same when I switch to S&Q: only 24p and 60p are available.
