1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
Amazon are collecting mine on Thursday, taking it back no problem even though I've had it since June, I think I'll wait for 2016 tv now, as it's more likely the 2016 tv's will land before an update for the 2015 line up.
Sorry to be a bore, but I personal think it is well worth it, and will be in the end for a lot of people, if those that are new, or are willing to stick it with these TV's till the end of either their 90 day cooling off before sending them back to log a complaint here https://ssl.bbc.co.uk/programmes/b006mg74/contact if they haven't done so already!
It may not fix any of the problems immediately, it may seem as if it is no point at all, but you don't know until you stand up and be heard. imagine if you will, if as someone said earlier, if SONY didn't just keep trying to release big updates (that keep getting pushed back) but instead concentrated on smaller or singular bug fixes at a regular basis, it would put a little more confidence in the consumer that they are working on and still supporting the 2015 sets! 5min is all it takes to fill in the form.
You're not being a bore - I agree with your points 100%.
I came back from holiday yesterday having switched the TV off at the mains.
I couldn't get any sound via ARC to the HT-XT1 from either my Humax FoxSat HDR or from a DVD player.
The TV sound worked fine, and the TV was saying that the sound base was connected, but no sound from it.
I cold rebooted the TV twice, no joy. Finally tried rebooting (mains plug out and back in) the HT-XT1 with the TV on, and the sound system sound came back on.
This thing is riddled with nasty bugs that would totally stump a non-techie user.
If it isn't sorted by mid October, mine is also going back to JL as I don't trust Sony's commitment to fixing the problems once new 2016 TVs are announced. Small incremental updates would go some way to restore that confidence - are you listening Sony - unfortunately, I think not.
We have not had much trouble with 49X8039C except that the Operating Instructions are impenetrable and so far I have found nothing useful by searching it.
Whenever it has crashed, needing a reboot, that seemed to have resulted from opening an app such as web browser, then continuing to try to do something else without closing the app which was already running, and maybe putting the Tv into standby can sometimes crash it for the same reason upon re-starting?
I think pressing 'return', 'return'...helps to get out first, or are there other ways round this?
The power button works a little strangely. It seems to require only a quick press and release to start the Tv but on pressing and holding it the Tv does not start until it is released.
On the other hand, with a universal remote, the duration of the command seems to need to be increased a bit.
Are these ideas off beam, or are there other tips?
Maybe I"ve been a little luckier than most, or just not playing with my TV (KD-55X8507) and the software as much as some users here. I have don't seem to have half the problems mentioned.
Issues:
All very annoying, but if I switch my DA-3300ES AV off and on again, it works.
However, regarding the software updates, consider iPhones and iOS 9. I have an iPhone 5s. It looks nice, the screen is pretty good, the build quality is excellent A similar parallel to my KD-55X8507 I would say.
But, I upgraded to iOS 9 the other day and it sucked. Then 3-4 days later there was iOS 9.1. So I upgraded.. and it still has bugs.... How many Apple software engineers are going to be listening, testing and working on the new fix I wonder? And how many issues do you think they are going to be testing? Not a couple. Not a hundred... they are going to be waiting until they have thousands of customers feedback so they can test the bugs with rigour to make sure that the update released will fix as many problems as possible. Otherwise there will be bitching and moaning that their fix didn't work for some people...........
That's how software development and update works. Is it not?
All in good time, when it's ready. Not each week or to a random date mentioned 6 months ago. Because as we all know, each user will create a new set of issues with their own customised set-up that I'm sure the Sony software engineers just don't have the man-power to recreate or forsee. Let's face it, this is a Google (lollipop) problem > androidtv
Just my opinion. I've had my TV for 3 weeks now. I'm happy to wait.
I purchased a 43w805c a couple of weeks back, I love the picture quality on it and to be honest I haven't seemed to have a lot of the issues most people have had.
One thing that is really annoying when I plug a USB in, to any of the 3 ports after a few minutes when I start to scroll through the options on the home menu it starts to make a horrible tinny sound after the "bing" noise, makes it sound almost robotic, it then affects the sound on films and programmes.
Does anyone have any ideas what it could be, does it need replacing before my 90 days are up. I can do a soft reset with the off button which seems to sort it but I cant do that everytime I plug a usb in.
Any help would be appreciated.
Thanks.
Hi Gunit1978
I have a KD43X8309CBU - think there's an option in the settings to turn off menu navigation tones. I have no noise when scrolling through menus, apps, or USB/NAS folders etc.
Might be worth checking your settings.
Hi
Thanks for replying, I did do that at first but it affects the sound on the tv as well afterwards, it makes it sound like there is rain or wind in the background 😞 when I reset sound is perfect.
The menu navigation tones seem to work whenever they want. I've got mine set on, but they're not sounding today.
In the audio settings, there is a clear audio option.... I found that turning this off stopped the hissing noise on any channel i was watching, including USB/NAS and VOD (Netflix/Google)
