1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
should be fine now, just renamed the link to remove the spaces.
Survey completed
If you're looking for a list of issues to ask people about, I compiled one here for the issues I have noticed myself:
http://www.redsilico.com/sony-2015-android-bugs
It doesn't have everything as, for example, I have not experienced the YouTube thing (yet). But I can add those. If you leave a comment on the post describing the issue, or link to a post on a forum that describes it, I will add them.
@anjenki75 wrote:If you're looking for a list of issues to ask people about, I compiled one here for the issues I have noticed myself:
I think you have nailed the items on my list. I am in negotiations with the retailer for a refund, as it is not fit for purpose, but I worry that I am naively hoping that none of these issues will occur on another TV from another manufacturer. Does anyone know otherwise?
Re: Going to YouTube on power up
I have found that I had somehow been signed in to YouTube on the TV. I signed out and the problem has gone - TV on power up
So is everyones opinion to return and try to get a refund or hold off unitl the 13th of October?
Note: ordered KDL-50W805C back in July from amazon and only powered it on once to check was working as currently in a house move but have been watching this thread closely.
my KDL-43W756C used to allways switch on to youtube app, I did a "press and hold" of the power button on the remote to reboot and the problem went away....
