2015 Bravia Android TV Issues
NickCo1979
Member
1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
6,373 REPLIES 6,373
apoc.reg
Explorer
Thanks for that - In general casting works fine from the BT sport app, youtube app from iphones or android tablets but its the Miracasting from a laptop running windows which wont work. Tried several some running windows 8 others windows 10 but not luck so far. Oh well!
gunit1978
Explorer
I have exactly that, all apps, phones and tablets cast perfect with no lag, last night I cast from chrome browser on my laptop and that played fine with a bit of judder and lag. The only one that hasnt worked has been selecting a file from a folder in a Win10 laptop, right clicking and selecting cast to device, just comes up with device error
theshamelessmanc
Member
@apoc.reg
Have you checked your network share settings for windows? I had a similar problem, I had to make sure that I gave permission to the Bravia to access my PC's. Now both WIN7 and WIN 10 can stream to the TV.
apoc.reg
Explorer
Ah ok, interesting. Thanks I'll check when I'm home!
t1mmm9879
Explorer
Hi All,
Just noticed the support page for my w805c is now down on my iphone which contains update details.... could this be the beginning of the firmware update?!
DaM3k0n
Member
@mr_robot wrote:
Still no sign of a UK update, there is however a US update that has been published today.
http://esupport.sony.com/US/p/model-home.pl?mdl=XBR55X900C&LOC=3#/downloadTab
Anyone know what the impact of pushing a US update onto a EU model TV will do?  I dont actually use the terrestrial tuner, only Sky +
Probably void you warranty!
Youd also think the TV would detect a foreign firmware and block it.....
^ You cant install it, the tv will tell you that the attached USB cant be
used for an update
t1mmm9879
Explorer
False alarm, still no update 😞
andrewsoong
Member
The optimist in me would say they're timing the release to pair with the Google announcements starting at 5pm.
We all know that's never going to happen, of course, the pessimist in me says there will be no update today and it's been delayed until late next month.
Al_Charles
Member
I will wait until 13th October. If nothing then I will return mine under SOGA.
i really don't think Sony care any longer.
