2015 Bravia Android TV Issues
NickCo1979
Member
1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
6,373 REPLIES 6,373
alellio01
Member
@UniBorg Sony sound bar (CT370) as example turns on and off with the TV. With this sony tv remote, I can control, TV, Sound Bar, DVD player and PS4.
UnoBorg
Member
Nice soundbar :-D...Yeah i was referring to richer sounds & other places & on here when peeps said sound bar doesn't come on with TV..... Least your's ok
profile.country.en_GB.title
tweety2b
Ex Commander (Was always on)
Hi guys, Just to clarify for the soundbars: only soundbars that support the Bravia sync control setting will allow you to use your TV remote for the soundbar. And I do believe Bravia sync is only possible via HDMI supported ones. Cheers Nico
Nico Henderijckx
(ex-Sony employee - fanboy forever)
tweety2b
Hi guys, And more news, the roll-out of the next firmware has started (depending on your model and region times may vary). It is improving overall stability and speed of use apparently. Cheers Nico
Nico Henderijckx
alellio01
Member
Morning Nico. You beat me to it, already downloading.. !
profile.country.nl_NL.title
tcviper
Explorer
Any other info then:  It is improving overall stability and speed of use apparently ? :slight_smile:
5.1 sound fix? HDMI sync fix? :slight_smile:
tweety2b
Hi Tcviper, I don't have the details but i do believe this update is mainly to improve speed and stability of the browsing/EPG/channels section. Nothing about sound or HDMI. I will keep on digging till I can bring you some good news ;-) Cheers Nico
Nico Henderijckx
What about the TV/Radio button on Freeview where it seemingly takes you to Channel 183 (AdultXXX.com) after the radio option. To recap one press of the button takes you to the last radio station you was listening to, another press then takes you to AdultXXX.com (when watching on Freeview) and a final 3rd press takes you to the last TV station you was watching
Will they be fixing this or will they issue everyone with a new remote chaning the TV/Radio button to state TV/Radio/Porn???
What am I meant to do in the mean time with my children. Do I hide the remote and make them ask me to change channels???
Poor Sony, Very Poor
tcviper
Explorer
Installed the new update, but is still the same speed/slowness when opening EPG, unfortunately.
NickCo1979
Member
Same poor performance here.
Changelog shows only stability updates, no performance updates.
