49XG9005 Netflix HDR
lucianpacurar
Explorer
Hi people,
I like HDR movies on Netflix, they look great. But when subtitles get displayed on screen, they burn through my retina and the TV changes the contrast of the scene a little. What TV settings do I need to adjust so that they don't burn that much? Else I will probably have to change the subtitles color to yellow and even make them translucent.
Thanks!
3 REPLIES 3
lucianpacurar
Explorer
Also disabling HDR for Netflix is an option. But there's no way to do it.
lucianpacurar
Explorer
https://www.rtings.com/tv/discussions/QuQQos17caLyr0CT/additional-review-notes
I'm assuming this could also be the problem, since the subtitles are significantly brighter than any scene.
stormyuk
I have similar with my XG9005. You can go into Netflix settings on your PC or Phone and change the subtitle colour in settings. I originally did this to yellow for my XE9005 but even with yellow its too bright. Someone suggested red. So I might try that next. :slight_smile:
You can also change the opaqueness (semi-transparent setting) but, to be honest it doesn't seem to help as while my phone shows it dimmer, the TV still is retina burn territory.
