49xg9005 Screen Surround
SOLVED
fatboyz62
Member
I seem to have a strange problem in that the thin metal screen surround seems to be 'charged', when I touch it I get a tingling feeling as if its live or has a build up of static. Has anyone else had this or any ideas ?
1 ACCEPTED SOLUTION
Accepted Solutions
Win_88
Specialist
Hi again,
Apparently, this is normal: https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/kd-49xg9005/artic...
I don't think there's anything you should worry about.
Win_88
5 REPLIES 5
Mick_D
Hi @fatboyz62
This is possibly due to a static charge build-up from carpeted floors, socks, low relative humidity in the room, or a combination of all three.
You may have a bad earth somewhere, which is another matter. Have you tested for that?
Mick
fatboyz62
Member
Socket is ok, no static from socks, carpets  etc. There is a voltage on the surround, have emailed Sony, waiting on their reply.
Win_88
Specialist
Hi there,
I'm interested to know the method by which you confirmed the socket is ok. Have you tested a different one for example?
Win_88
fatboyz62
Member
The socket was tested by an electrician, he used a plug in device that tested the earth, and the RCD in the fusebox. Im not sure what it was called, sorry.
Win_88
Specialist
Hi again,
Win_88
