hi all, after applying this latest firmware, my tv has become alot dimmer , after factory reset still the same , enhanced format hdr colours are not the same as the were in previous firmware v5.417, hdr luks dim and fuzzy,, please any way to downgrade back? im gutted , never should have updated!! this new firmware does not
What firmware version is the latest?
5.433, same as topic name.
morning, do you mean motionflow is still on after disabling it? are you watching movie through netflix or usb or bluray? ill try a movie now , see if i can see what is goin on loll edit.. just watched avatar , smoothing is off after disabling motionflow and film mode , maybe you have to factory reset your tv
Yes in menu it is disabled but visually it looks like it’s enabled: over the top smooth motions. Like mentioned here https://www.cnet.com/news/tom-cruise-fights-the-soap-opera-effect-for-mission-impossible-fallout-blu...
i always use use my Apple TV 4 connected to hdmi/arc
Hi I normally have standard for motionflow but noticed after update that its using smooth. So basically they are the same setting. Its annoying as the soap opera effect is awful! I am using true cinema for now but it's quite stuttery. Hoping for a fix soon!
hiya i use true motion too, cant see any stutter , but i always keep fim mode off , now that causes stutter loll
Why is film mode bad? I use true motion Smooth becuase i like it.
Thanks for the tip
