AF9 65
Bernard1970
Explorer
AF9 65
Hi,
I purchased the AF9 65 in March this year, connected Bose 7.0soundbar through Arc. Things have been going well till now. If I use Alexa on the soundbar the speakers go back to the TV speakers and then the TV switches off after 20mins, switch T.V back and it continues to switch off. Any ideas why TV goes back to default speakers when trying to use soundbar?
7 REPLIES 7
Pascale_F
Hi Bernard,
Welcome to the community.
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
Bernard1970
Explorer
Hi Pascale
Thanks Pascale appreciate your help.
Thanks Lee
The_Black_Rose
Specialist
Hi Bernard1970,
That sounds a bit unusual. This might be related to the software, are you sure you've the latest software update installed? You can download it through this link: https://www.sony.co.uk/electronics/support/oled-tvs-android-a9f_af9-series/kd-65af9/downloads/000159...
Cheers,
The_Black_Rose
Bernard1970
Explorer
Hi Black_Rose
Thank you for the suggestion but the TV has the latest firmware already checked. Thanks anyway.
The_Black_Rose
Specialist
Hi Bernard1970,
Can you try factory resetting the TV? You can find the steps here:https://bit.ly/2qNPwro
Cheers,
The_Black_Rose
Bernard1970
Explorer
Hi Black_Rose.,
I've been advised by Bose as my TV is wall mounted and connected to a Bose
soundbar, which is wall mounted, to change the HDMI lead, disconnect the
power lead and re-connect. If that doesn't work then try reset as you
advise. I'm on holiday at the moment, but as soon as I get back it is the
first job. Thanks for the advice.
Thanks Bernard.
The_Black_Rose
Specialist
Hi Bernard1970 ,
Let us know how it went once you try it.
Cheers,
The_Black_Rose
