Hello.
During CES I heard a news that Sony will bring Android 6 (Marshmallow) to the 2015 TV lineup.
General News about Marshmallow on Android TV's
These news are from January.
Had anyone heard something new about this?
Hello,
i have downloaded the .pkg file and copied it to a USB drive. however each time i connect the usb drive to the TV it only showes the "view images/movies" window. its like its not detecting the .pkg file at all.
Do i need to format the USB in any specific filesystem?
Thanks!
@kutufluix wrote:
Hello,
Thanks!
Hi there
Suggest trying another USB drive if you have one - Formatted to FAT32 and when copying the .pkg file, ensure its not placed in a folder.
Hi Quinnicus. Can you report that the video app isn't showing widescreen correctly? It stretches widescreen vertically by about ten percent (see my earlier post) Thanks very much.
FAT32 worked thanks
@Anonymous
Thanks for reminding me to give a wider description. As a software debugger, I should have been more thorough.
1. It is happening with all the channels in my favourite list.
2. There is no difference between HD and SD
3. DVB/T/2
It looks like there is the normal info banner and a new one, a favourite info banner. If I'm in the favourite list, the new banner is on top. If I press the info button it shows single, old type of extended banner.
Outside the favourite list there is only the old banner.
When I noticed this, first thing was a factory reset, but no help.
Dear all
If you are experiencing the Amber/Green Blinking LED lights - a break-away thread has been created. Please see:
@vick18 - I have moved your post to this thread too.
PS: At current, there is no fix as far as I am aware.
Hi, i installed the update yesterday. Did you unzip the downloaded file before copying it the USB drive? The instructions miss that part out 🙂
Hi Graallen
Yes, unzip the file you have downloaded and then copy the .pkg file to the root of the USB drive. It is in the instructions (Number 3 I think)
Hi Marcd51 I read your post although I have had no issues with the update I notice you advise a factory reset after an update. As I have never needed to do this can you tell me how do you actualy do a factory reset and what info do you loose i.e. will I have to re tune my satalite tuner , will i have to re install the apps I downloaded etc.
thanks
@djmickey83 wrote:
@Anonymous
@djmickey83 - I have reported the double overlay of info banners to Sony.
You should know better being a software debugger!! ROFL
