Bravia/Android keeps rebooting every 2-3 hours whilst in use
SOLVED
RobinPeter
Explorer
Hello All,
I have searched for this subject with no success?
My 10 month old Bravia Android (KD43XH8096BU) keeps rebooting/restarting every 2 or 3 hours
whilst we are using it?
Is it a problem since a update? Has anyone else experienced the same?
Sometimes the volume stops working too & I have to unplug it(TV) for a minute to get it back!!
What are the recomendations for curing it?
Thanx in advance folks.
Tags (1)
1 ACCEPTED SOLUTION
Accepted Solutions
Hi there,
Do a soft reboot via the remote control and make sure your FirmWare is up to date. Also, put update to automatic if you are connected to the internet.
Per
Sony Support
51 REPLIES 51
Eskimosony
Member
Try two simple things first, brand new batteries in the remote and a factory reset. It could be spurious output from the remote or a third party app causing the problem. Fingers crossed either of those fixed it.
ExpatScot
Member
Not for me - persists after resetting.
Eskimosony
Member
Same Model? If so contact Sony Support
RobinPeter
Explorer
Eskimosony.
I have tried a power reset  with the remote control & thought it had cleared it, but I'm not so sure?
Of course it means being in the room to see it happen & that isn't always possible!!
Have you the contact details for the Sony Support you suggest please?
Thank-you
RobinPeter
Explorer
Thank-you so much. I have done a few of the suggestions on there now and will wait and see if they work during viewings in the next few days!!
Thank-you again.
Eskimosony
Member
Ace, Robin if it fixes it be sure to come back and tell us and mark the solution for other users👍
SimboSims
Explorer
My Bravia has exactly the same problem - pure random event and can't replicate. Back to John Lewis service centre who changed the mainboard and it rebooted twice on restarting with latest firmware. AV forums tend to think it's a firmware problem as it is a common event since its release and can only be fixed with a new firmware whenever it will be available.
Eskimosony
Member
Good luck with that firmware update...it's 1x a year if you are lucky...
