Bravia XG95 - Youtube freeze fixed
Simpleman10
Member
I’m posting my own solution as it may help others if they have a similar problem with Youtube.
For no obvious reason I found Youtube stopped working. Firstly there was a black screen, then I could see the videos but when I tried to play the video it would freeze.
Firstly I cleared settings from Youtube which didn’t fix it.
I was reluctant to go straight to a factory reset.
I fixed it by doing a ’power reset’, which is simply unplugging the TV from the wall socket for 1 minute. Youtube was working fine again when I switched the TV back on. I’m not sure if clearing the Youtube cache first helped.
It seems to be like computer problems - try a reboot first before messing with too many settings.
1 REPLY 1
Simpleman10
Member
Seems that an alternative reboot method is to hold down the power on/off button for about 5 seconds.
