There you are, @Anonymous, as requested:
Before upgrading my 49XD8099 to Android 7.0 I had this scenario:
After upgrading to 7.0 I tested what was the situation:
So I did a factory reset.. And this became the situation:
All was fine until few hours later, when the /sdcard became Read-Only again! i could not copy any more files (58GB free). The Memory Setting was nearly untouchable because it was a crash after another. The only USB operation I could do from the tv has been to format the pen drive as external and that (I think) restored the internal memory as internal memory (losing the content but there wasn't much).
Oh, I also tried to use the old HDD again, but the crashes when clicking on any app location were constant again so I gave up. I didn't touch it since, to avoid another headache.
Seriously? You've got 200Mbps over WiFi? Effective or just the reported connection speed by some app?
Effective and stable. Protocol has been TCP.
However, the TV has its own access point in direct line of sight (~4m away) with its own uninterrupted 80MHz wide WiFi channel. So abolutely perfect radio conditions...
I´m facing the same problem, now with Android 7.0 imposible to connect a usb pen drive like internal storage, with Android 6.01 was posible although quiet often (2-3 month) and suddenly, when I opend any app was migrated in the pen drive, the app seems don´t work getting stucked. It´s a big mess and disapointing from sony...
