Recently my tv has starting showing a shadow on each side of tv. Can only see it when a light background. Any way to get rid of it? Pretty sure it is not a burn in image as tv hasn’t been on pause for hours on end. This only appears on Netflix. No shadows on sky tv...
Which tv are you talkng about? In any case it is really strange that it happens only on Netflix, if you have any problem with the panel it will show even on the home menu....
