google play movies in 5.1 audio
ukbob1970
I have my kd49xd7005 on the latest firmware hooked up to my 5.1 amp (sony by the way) via optical and have no problem with netflix or amazon playing movies etc in 5.1 audio.
I have just rented a movie from google play (end of year deal only 99p) but cannot get it to ouput in 5.1 audio.
Please don't tell me googles own ecosystem is worse on their own android tv than their competition.
Anonymous
Non applicable
Hi there
Google Play Movies does support 5.1 Surround Sound, see pic:
However Dolby Digital Plus is only supported via a HDMI connection
Although as I understand it, some Google Play Movies do support 5.1 via multi-channel PCM - try setting "Digital Audio Out" to PCM - the setting is in the sound settings of the TV (not in Action Menu though).
11 RÉPONSES 11
Anonymous
Non applicable
Hi there
ukbob1970
thanks for your help again Quinnicus I do appreciate the time you put into all this.
profile.country.AT.title
Kuschelmonschter
Champion
Google Play Movies only have a DD+ stream. The DD+ decoder as built into Sony TVs can however downconvert that to 5.1 DD and output via both, HDMI-ARC and S/PDIF.
A TV typically only has HDMI inputs and HDMI-ARC, but no HDMI outputs. So they can't output 5.1 PCM. But as already mentioned, 5.1 DD is supported which DD+ can be converted to.
vincentbrice
I have exactly the same problem on my exact same TV. I too have it hooked up to a Sony 5.1 amp (STR-DB840) with the TV’s optical out. I too rented a google play movie that would only play in stereo.
However, when I watch the same film on google play via my Roku 3 connected to my TV via HDMI, the TV then outputs the full 5.1 to my amp!
It also loops 5.1 from my XBOX 360 to my amp in the same way, but as with google play, it won’t output 5.1 direct from the TV’s YouTube app.
It will output 5.1 from a video on a USB stick.
Anybody work that lot out?
profile.country.ES.title
Antonio_65
Hi,
can you still play Netflix in 5.1 with latest firm? I cant in my TV same model as yours
thanks
Kuschelmonschter
Champion
Check out Settings > Sound > Digital audio out. Latest FW set this to PCM for me, guess to mitigate Amazon Video syncing issues. Set it to Auto 1.
vincentbrice
I had to return the TV for a separate issue and have replaced it with a Samsung. That too only outputs stereo from it's own internet connected apps. So I have to use my Roku 2 to get 5.1 from those sources.
RedHagar
This still doesn't work for me. I have my TV audio out going through an optical cable to my receiver. My receiver doesn't support HDMI 2.0. There is no option on my TV (Sony x900e) for PCM. There is only Dolby Digital and Dolby Digital Plus. I recall reading somewhere not to use the Plus option but neither option makes any difference.
This solution does NOT see to work for me...
RedHagar
Nope, that doesn't work for me. Contacted Sony support and they couldn't get it to work either. Netflix works fine.
