HDMI ports stopped working after firmware update (v6.8022) on TV a80j
J_L_83
After updating the firmware to Android 12 on Sony TV Bravia XR-55a80j, the HDMI ports have stopped working. When I select the HDMI port as the source, I can't see the image sent from the connected PS5, Apple TV and Sky Box Q.
Changing the port or cable does not help. I tried changing the HDMI standard, enhanced, Dolby Vision, and VRR modes, but none of the settings helped. I also tested Disabling CEC (Bravia sync), clearing the ExternalInputServices application data and cache, turning everything off, and plugging in one device at a time. All without any result.
Is there anything else I can do, or should I wait for the new firmware?
If the TV is out of warranty, does support take care of fixing the issues caused by the firmware update?
J_L_83
I was able to solve the issue by conducting a factory reset. Unfortunately, I had to set up everything from scratch.
J_L_83
graygerman
ive similar issues, my freesat not showing on the hdmi its connected to, however ive way too much stored on my tv and im not gonna do a factory reset because i already know it failed for others and theres a 50 / 50 chance it wont fix the issue.
Sony need to give their heads a wobble, who the hell coded this android 12 update for sony, a 5 yr old!!
