KD-49XF8096 - iPlayer error 02056
slipd83
Explorer
Hi guys,
As above. We've been unable to view anything on iPlayer, we just get greeted with the unable to play error code 02056 when making a selection.
Restarting the TV hasn't helped.
Any other things to try? The TV is fine apart from this, Plex, Netflix and Disney+ all work etc.
Thanks!
27 REPLIES 27
LightFoot
Specialist
Hi @slipd83
Is you TV software up to date which will include the latest iPlayer software as well?
https://www.sony.co.uk/electronics/support/lcd-tvs-android-xf80xx-series/kd-49xf8096/software/002829...
For completeness I would reboot your broadband router, just in case it is blocking the connection to the iPlayer servers.
slipd83
Explorer
Yep, all updates are applied as they come - and I did check and we are on the current offering. Will reboot the router tomorrow and check the DNS servers etc., I've read they can cause issues with iPlayer as well.
Anonymous
Not applicable
Try to disable and enable YouView once more, and go to ''Help'', then go the privacy settings, and re-accept it all, then test it once more.
slipd83
Explorer
Thanks! Will try tomorrow. I have established that it isn't my internet that's the problem, the issue is definitely with the TV... latest update installed but I was wondering if it might be worth performing a factory reset?
We're currently watching iPlayer through our Sony Blu-ray 😂
slipd83
Explorer
Sorry, you mean iPlayer yeah? I was actually wondering if it was possible to force stop apps and clear caches etc.
I'll give it a go!
HannahEd01
Hey slipd83, if you tried all of the above and the issue remains, it's time to perform the factory reset. Here are the steps:
https://helpguide.sony.net/tv/faep1/v1/en/08-01_03.html?hl=factory
slipd83
Explorer
Yeah, I think it's coming up to that time...
All of the UKs terrestrial steaming services appear to be embedded in the Sony Select app set you can't force stop or clear individual caches.
Thanks all!
HannahEd01
Hi slipd83, if you go Home- Settings_ apps- show all apps, then go through the list.
slipd83
Explorer
Bah, Factory Reset doesn't appear to have done anything...
