Connected ps4 controller to Bluetooth on tv, but controller not working.
KD-55XD7005.
Hey @Garyjames7878 it seems that your model doesn't support the correct Bluetooth profile to connect to the TV as it works with an A2DP which is not supported by the TV as per the specs here so in this case you can check if properly with the PS support team if they can check it for you.
