"Unfortunately Sony Select has stopped" error
bbbullock
Hi,
Intermittently I get a "Unfortunately Sony Select has stopped" box popping up on the screen and I need to click "OK" to remote it. It often pops up several times until I carry out a reset my holding down the green power button on the remote for 5 seconds. Does anyone know what is causing this "Sony Select" issue?
Thanks!
2 SOLUTIONS APPROUVÉES
Jecht_Sin
Passionné
I get all kind of force closes like that, HueyModule for starting (even after the reset to factory settings!) and even the Settings app/service itself. They are bugs with the OS. In your case you should be lucky, just disable that useless app in Settings (go to Settings/Apps in system apps select Sony Select and then disable it. The option should be there) and forget about it. Otherwise you may try clearing its data in the same settings.
bbbullock
Jecht_Sin
Passionné
bbbullock
Many thanks!
