Hi
I've recently bought Sony Bravia KD-49XE8396 Android tv that's connected to SKY dish via SKY+HD box. But I've cancelled my sky subscription, so this box is now used as a freeview device. I've also registered a 1TB external HDD as a recording device. However, when I try to record any program, it tries to record it on Sky+HD box which is not allowed as I'm not a sky customer anymore.
Is there anything I could do to force recordings on HDD?
Thanks
@hemant_verma2000 wrote:Hi
Thanks
Hi @hemant_verma2000. It sounds like you are looking at the Sky+HD TV Guide. This clearly will not work as you do not have a Sky recording subscription. You need to set your recording from the TV Guide on the TV (Youview or Sony native) to record on the registered external HDD.
Sorry to hijack
but once a hard drive is setup and registered to record on the android tvs
may i ask firstly does it format the hdd to a sony specific ?
or does it leave current file system in tact
i ask as i have a 2tb ntfs hdd
and on it i have movies
thanks
@dave11674 wrote:Sorry to hijack
thanks
Hi @dave11674. It formats the HDD so you will lose everything recorded on it. It does warn you ...
