Sony Bravia kd-55xe8396
akredfearn
New
The red led flashes 6 times. I have done a factory reset and it was ok for 3 days. Now reappeared and the factory reset does not fix it. It is quite old but worth fixing if not expensive.
Any ideas what the problem is?
2 REPLIES 2
LightFoot
Specialist
Hi @akredfearn   I’m afraid that six flashing red lights is probably the power board has failed. It will cost you more to get it repaired than to buy a new one.
You could try Sony Support, they will make you jump through hoops like insisting on seeing the original invoice etc.
https://services.sony.co.uk/supportmvc/en/Contact/Email?cat=televisions-projectors1
akredfearn
New
Many thanks for this.
Adrian
