sony chennel editor v1.2.0
SOLVED
profile.country.HR.title
Hazl113
Explorer
I have installed this program but cannot start it. Do I need a 64 bit OS? I have Win7/32.
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.IT.title
Marino.Manolo
Do you have Java installed?
If you want to try (and if you trust me...), I've realized a Portable Versione:
https://mega.nz/#!btdSFA4J!nZigkagp4pf8GjbtyMe8TdAlyEYlHCxH879EsBAEddY
2 REPLIES 2
Marino.Manolo
Hazl113
Explorer
I have a little problem writing here. I installed Java and still does not work.
The message is:
This verison of this file is not compatible with the version of Windows you're running. Check your computer's system information to see whether you need an x86 (32-bit) or x64 (64-bit) verion of the program and then contact the software publisher.
