Sony XF-9005 v. 6.6545 update seems to cause stutters
profile.country.SE.title
jonas740
New
Sony XF-9005 v. 6.6545 update seems to cause stutters. You know the issue when it changes scene and the first few frames stutter. Same issue XE9005 has
I also have a Sony XE-9005 with the previous version and that one is far more smooth. Weird since the processing power in XF should be a lot better.
2 REPLIES 2
Ryanm1701
Member
I have the same TV, 65 inch model and the same firmware and dont experience any stutters. What application are you experiencing this issue in? Or is it via HDMI?
Have you hard reset the TV since installing the update?
punnorg
Explorer
On the 75". No stuttering during playback but there is some occasional lag on the Android home interface. Could be background apps.
