As the ethernet port on sony TV only do upto 100 mbps if I was to put a USB 3.0 gigabit ETHERNET ADAPTER into sony x94j usb 3 port and used a tp link gigabit ethernet adapter would it work.????
If you got it off Amazon, returns are easy and straightforward.
Thanks for that did not realise Amazon would allow returns unless faulty.
Big thanks to @LightFoot and @royabrown2 for your advice, UGREEN has been sent back to Amazon today and UE300 has been ordered.
Well my TP-Link UE300 arrived today and all good.
Using wifi I would get 312 Mbps down and 264 Mbps up now get 939 Mbps down and 911 Mbps up.
what a big difference 😀
Hi, I have a K-85XR90 and the TP-Link UE300. The USB Ethernet Adapter worked out of the Box. The problem is that I can not switch on the TV anymore when the Adapter is pluged in. I have to disconnect power and after connecting power again I have to press the "ON" button in remote for ~10s to restart the TV. I also tried the developer USB settings with same result.
Any ideas?
Hi @AlexKid
The firmware on these Bravia 9 TVs is completely new, perhaps you have discovered that the UE300 is no longer compatible. The UE300 is now an old model so it may be you need a newer model. Useful information for the community.
I take it you have tried all the USB ports.
What amazes me, that in 2024 Sony are not using 1 Gb network cards. It must be difficult to source old 100 Mbps chips! I take it you have tested the native network Ethernet speed?
Hi,
you are right. For the newest Bravia 9 Series we need a newer USB3 Ethernet Adapter. I searched a while and ordered this one:
I tested it for one week now without any problems
