Virgin 360 stb
Brentgardiner
New
Virgin 360 stb
Just purchased Sony X-ray 55inch oled tv, does anyone know if the remote control will operate a virgin 360 stb?
thanks.
2 REPLIES 2
Joe_Dohn
Specialist
Sadly, the model number seems incorrect. However, most Sony Bravia TVs feature support for Bravia Sync which allows you to control external devices that are connected via HDMI.
ians325
New
For Some Reason Sony Have not updated there firmware to recognise Virgin 360 Remote or Update.  But there is a work around.
With  your Sony remote go to Settings > Channels & inputs > External inputs > TV box setup > Setup by model number (try  DCX960) > TV box > Set up > select the HDMI input  that your 360 is plugged into > type in Ziggo > type in Mediabox (or Mediabox Next)
If your menus are different then try
Settings > Watching TV > External Inputs > TV Box Setup > Setup By Model Number > Setup > Select your HDMI that your 360 is plugged into >type in Ziggo > select Ziggo and press OK > type in DCX960 and press Enter > select DCX960 and press OK.
Then Goto your Settings External Inputs, Manage Inputs >HDMI - Ziggo > Custom Name and Rename to Virgin TV 360
