HDR-HC5 LCD "tracking" problem
SOLVED
profile.country.en_GB.title
penthor
Visitor
Remember years ago, when TVs were full of tubes, and there was a "tracking" adjustment.  If the picture kept scrolling up or down, you could alter the tracking until the picture steadied itself.  Well, when I open the LCD on my camcorder, the picture keeps on scrolling upwards, refreshing itself from the bottom.  When I flip the screen through 180, then it sorts itself out.  Any ideas what could be causing this.  The picture is fine through the view finder.
1 ACCEPTED SOLUTION
Accepted Solutions
Mick2011
New
Hi penthor, welcome to the Sony Forums :slight_smile:
It's a little unusual to get that fault but I'm quite sure it's due to a broken ribbon cable. This is the connector that passes through the hinge of the articulated screen. It's a common enough problem with older cameras but this model is quite recent :thinking:
If it's still under guarantee you can register it for a repair here: http://www.sony.co.uk/support/en/repair
Mick
1 REPLY 1
Mick2011
New
Mick
