Maximum size of SD card on HDR-PJ260VE & NEX-5N
SOLVED
profile.country.en_GB.title
girneli
Visitor
Hi, i would like to purchase this card if its ok with my both sony devices..Sorry about my poor english and thanks all.  http://www.sandisk.com/products/memory-cards/sd/extremepro-uhs-1-95mbs/?capacity=64GB
1 ACCEPTED SOLUTION
Accepted Solutions
Mick2011
New
There's no physical restriction to the card capacity for either camera.
You should be aware that anything over 32Gb will be SDXC format, which does have some restrictions on some devices: see this wikipedia article and this Sony Forums sticky, for example. But as they are SDXC-compatible, both cameras should work fine with any SDXC card.
You can check the PJ260 specs here, and the NEX-5 specs here.
Mick
5 REPLIES 5
Mick2011
New
Hi girneli, welcome to the Sony Forums :slight_smile:
Yes, that card is compatible with both of your cameras :cool:
Be sure to buy a genuine card from an approved SanDisk reseller – see 'Where to Buy' on the page you linked to.
Mick
girneli
Visitor
I call sony and they told me both i can use max 32GB SD cards.64GB size its fine? how about 128GB SD Cards ? Where i can find my self more info. ?
Thanks
Message was edited by: girneli
Mick2011
New
Mick
girneli
Visitor
Thank You..
Mick2011
New
You're welcome :cool:
