Hello, I have recently taken video and stills with my Sony TG3, and want to burn them onto DVD. Every time I try do this, I get a message saying some files will not be copied because the files are not supported. Video files copy no problem, its just the stills. I have tried to burn just the stills, but I get the same message, can anyone help?
Hi JB, welcome to the Sony Forums
There's no reason why an image file won't be supported; it's probably flagging up something in the file directory that's not required.
How are you copying the files? It may be that simply copying direct from the camera will include files used to read the images when transferring to PC. Using an image editing program (like the one that came with the camera) should deal with the un-needed files and leave you with only the images.
Mick
