Vista Driver for DCR-HC42E
SOLVED
profile.country.en_GB.title
Visintini
Visitor
I am running Vista Business and need an updated driver for dcr-hc42e handy cam do you know if there is one?
1 ACCEPTED SOLUTION
Accepted Solutions
Blencogo
Hi Visintini and welcome.
There is no available USB driver for Vista or Windows 7 so the USB connection will not work.
To transfer Video from the Camcorder to a Computer, you need to use an iLink (also known as DV or Firewire) cable.  An iLink connection is supported by Windows without additional drivers.
http://www.amazon.co.uk/Ex-Pro-Standard-Sheilded-Professional-VMC-IL4415/dp/B003D1SI8O/ref=sr_1_11?s...
You can then import video using Windows Movie Maker or another editing program.
This, of course means you need an iLink port on your computer (or a card slot that will take a firewire card).
:thinking:
2 REPLIES 2
Blencogo
:thinking:
Visintini
Visitor
Thanks for the info!
Seems a bit of backwards thinking by Sony!  I would have expected them to be ahead of the curve, not behind it!
Must check my PC Ports!
