DSC-H300 Cyber-shot only saving 5 images
ShaunJ
New
Hello, I have been using this camera for a number of years with no issues, but after my SD card became physically damaged I started using a replacement SD card (Sandisk). I formatted the new SD card but find I can only take 5 images that are stored correctly, any other images are not. When I transfer imaged to my laptop images 6 onwards show as 'file empty'?
I believed it was a faulty new SD card, and the supplier sent me a replacement, but it has the same issue.
I have re-initilized the camera, but the fualt remains. I'm guessing there must be an internal fault but was wondering if anyone has experienced similar?
Thanks
Shaun
12 REPLIES 12
Pascale_F
Hi Shaun,
Welcome to the community.
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
profile.country.IT.title
Marino.Manolo
A question, the memory card is formatted in the camera or via computer?
Manolo
ShaunJ
New
Hi there.
I've gone through the format process via the camera.
Thanks
Tenneen9000
Member
Hi Shaun,
Sounds terrible. One question though. What is the size of the SanDisk memory cards you used?
Regards,
Tenneen9000
ShaunJ
New
It's a SanDisk ultra 32gb. Previous one was a SanDisk 8gb.
I've ordered a standard sandisk just in case there is a problem with the
ultra - can't see why, as it's in the list of compatible SD cards for this
camera type.
If the same issue occurs, it's got to be pointing to the camera being at
fault.
Thanks
ShaunJ
New
So I ordered a bog standard Sandisk SD card, as upposed to the Ultra ones I have been having the issues with.
Formatted it in the camera and it storing images fine thankfully.
Very odd, as the ultra is in the recommended list for this camera.
Thanks
petegeoff
New
One of life's mysteries!
The_Black_Rose
Specialist
Hi ShaunJ,
I'm happy to know that you've manged to resolve this but I was wondering did the memory cards you were using match the specifications mentioned here: https://bit.ly/2N27jFH ?
Cheers,
The_Black_Rose
ShaunJ
New
Hi there, I went on the Sandisk site and checked the compatibility there.
the card used is clearly on there. only thing that is different is the
80MB/s but that wouldn't cause the problem? The one on the site states as
40MB/s
https://pct1.sandisk.com/ProductPage.aspx?ID=11709
[image: Capture.JPG]
Virus-free.
www.avg.com
<#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
