Hello,
I have an old DSC H50 camera with a 4GB memory stick pro duo card. These cards are getting rather hard to obtain, and I would like to increase the storage capacity on the camera.
I was wondering if it was possible to use a micro SD card using a micro SD to memory stick pro duo adapter in the camera?
Solved! Go to Solution.
I'm reporting back since I decided to "sacrifice" $2 to see if it would work, and I can confirm it does.
Basically I am able to use a 32GB micro SD card in the camera using that cheap adapter. There probably are fake adapters out there, but the one I chose works.
Hey Impavid, I don't think that's possible.
