Viosport 3 helmet cam compatibility
SOLVED
Viosport
Explorer
Viosport 3 action cam with 3 pin input jackViosport 3 action cam with 3 pin input jack
Sony input jack does anyone know which camera this is compatible withSony input jack does anyone know which camera this is compatible with
1 ACCEPTED SOLUTION
Accepted Solutions
IamNic
Hello @Viosport,
the connector in the middle would be a TRRS connector, yet with the proprietary connectors next to it, you wouldn't be able to connect it to any Sony camera.
Also why would you want to connect one camera to another camera?
- Nic
2 REPLIES 2
IamNic
Hello @Viosport,
- Nic
Viosport
Explorer
Thank you for the information the viosport 3 has to be connected to a recorder according to the manual the plug on the one I have is a Sony only plug  I have read on some American forums that this has been used with Sony handy cams I have been really struggling to find a compatible recorder, thank you for your response
