Partilhe a sua experiência!
Abortion Pills in Dubai – Abu Dhabi Sharjah +971568316598
there are many pregnant women who want to have an abortion with medication. Due to the demand for confidentiality or fear of abortion, some patients want to abort using drugs. You should consult your doctor about how to use drugs. Sometimes the use of these drugs can be risky. Therefore, use the abortion medicine with the help of a doctor, not yourself. Abortion Drugs are Cytotec and Misoprostol. Sale and use of these drugs is prohibited.
What do I need to do before I take the abortion pill?
Before you take the abortion pill, you'll meet with your nurse, doctor, or health center staff to talk about whether abortion is the right decision for you, and what your abortion options are. You'll get an exam and lab tests, and you may get an ultrasound to figure out how far into your pregnancy you are.
Your nurse or doctor will let you know if there's anything else you need to do to prepare for your abortion. They'll give you written instructions on how to take your pills. You will have access to a caring professional through the process — you'll get a number you can call 24/7 if you have any questions or concerns.
You'll have a lot of bleeding and cramping after you take the second medicine, so plan ahead to make the process more comfortable. You can be at home, or wherever is comfortable for you to rest. You may also want to have someone you trust with you (or nearby) that you can call for support if you need anything
Stock up on maxi pads, food, books, movies, or whatever you like to help pass the time, and a heating pad for cramps. Make sure you have some pain medicine — but don't take aspirin because it can make you bleed more.
What happens during a medication abortion?
The abortion pill process has several steps and includes two different medicines.
First, you take a pill called mifepristone. This medicine stops the pregnancy from growing. Some people feel nauseous or start bleeding after taking mifepristone, but it's not common. Your doctor or nurse may also give you antibiotics to take to prevent infection.
The second medicine is called misoprostol. You'll either take the misoprostol right away, or up to 48 hours after you take the first pill — your doctor or nurse will let you know how and when to take it. This medicine causes cramping and bleeding to empty your uterus.
For most people, cramping and bleeding usually starts 1-4 hours after taking the misoprostol. It's normal to see large blood clots (up to the size of a lemon) or clumps of tissue when this is happening. It's kind of like having a really heavy, cramps period, and the process is very similar to an early miscarriage. (If you don't have any bleeding within 24 hours after taking the second medicine, misoprostol, call your nurse or doctor.)
The cramping and bleeding can last for several hours. Most people finish passing the pregnancy tissue in 4-5 hours, but it may take longer. The cramping and bleeding slows down after the pregnancy tissue comes out. You may have cramping on and off for 1 or 2 more days.
You can take pain medicine like ibuprofen about 30 minutes before you take the second medicine, misoprostol, to help with cramps. You can also take anti-nausea medicine if your doctor or nurse gives it to you. Don't take aspirin, because it can make you bleed more.
It's normal to have some bleeding and spotting for several weeks after your abortion. You can use pads, tampons, or a menstrual cup — whatever's the most comfortable for you. But your nurse or doctor may recommend you use pads for the first few days after the abortion so you can track how much you're bleeding.
The last step is to follow up with your nurse or doctor. You may go back into the health center for an ultrasound or blood test. Or you'll get a pregnancy test to take at home, followed by a phone call with your nurse or doctor. These tests will make sure the abortion worked and that you're healthy.
In the unlikely case that the abortion doesn't work and you're still pregnant, your doctor or nurse will discuss your options with you. You may need another dose of medication or to have an in-clinic procedure to complete the abortion.
من
النساء الحوامل اللواتي يرغبن
في الإجهاض بالأدوية. 1 الإجهاض باستخدام الأدوية. يجب عليك استشارة طبيبك حول كيفية استخدام الأدوية. بالمخاطر. لذلك ، استعملي دواء الإجهاض بمساعدة طبيب وليس بنفسك. أدوية الإجهاض هي سيتوتك وميسوبروستول. يحظر بيع واستخدام هذه الأدوية
:+971568316598 Buy Abortion pills in Dubai, Sharjah, Abu Dhabi, Fujairah, RAK, Al ain, Dibba and Jumeirah. The Women’s Center of Hyde Park (Tampa Abortion Clinic) was established in 1998 and is located in the beautiful, Lake shore District of Hyde Park in Tampa Bay. It has been serving the State of Florida and the United States for over 20 years. Our Abu Dhabi, Ajman, Al Ain, Dubai, Fujairah, Ras Al Khaimah (RAK), Sharjah, Umm Al Quwain (UAQ) United Arab Emirates Abortion Clinic provides the safest and most advanced techniques for providing non-surgical, medical and surgical abortion methods for early through late second trimester, including the Abortion By Pill Procedure (RU 486, Mifeprex, Mifepristone, early options French Abortion Pill), Tamoxifen, Methotrexate and Cytotec (Misoprostol). +971568316598 The Abu Dhabi, United Arab Emirates Abortion Clinic performs Same Day Abortion Procedure using medications that are taken on the first day of the office visit and will cause the abortion to occur generally within 4 to 6 hours (as early as 30 minutes) for patients who are 3 to 12 weeks pregnant. +971568316598 When Mifepristone and Misoprostol are used, 50% of patients complete in 4 to 6 hours; 75% to 80% in 12 hours; and 90% in 24 hours. We use a regimen that allows for completion without the need for surgery 99% of the time. All advanced second trimester and late term pregnancies at our Tampa clinic (17 to 24 weeks or greater) can be completed within 24 hours or less 99% of the time without the need surgery. The procedure is completed with minimal to no complications. +971568316598 Our Women’s Health Center located in Abu Dhabi, United Arab Emirates, uses the latest medications for medical abortions (RU486, Mifeprex, Mifegyne, Mifepristone, and early options French abortion pill), Methotrexate and Cytotec (Misoprostol). The safety standards of our Abu Dhabi, United Arab Emirates Abortion Doctors remain unparalleled. They consistently maintain the lowest complication rates throughout the nation. Our Physicians and staff are always available to answer questions and care for women in one of the most difficult times in their life. The decision to have an abortion at the Abortion Clinic in Abu Dhabi, United Arab Emirates, involves moral, ethical, religious, family, financial, health and age +971568316598 considerations. Buy abortion pills in Dubai Buy abortion pills in Oman Buy abortion pills in Abu Dhabi Buy abortion pills in Sharjah Fujairah Buy abortion pills in Ras Al Khaimah (RAK) Buy abortion pills in Ajman Buy abortion pills in Al Ain Buy abortion pills in Umm Al Quwain (UAQ) Buy abortion pills in Kuwait Abortion Pills Available In Dubai Abortion Pills Available In UAE Abortion Pills Available In Abu Dhabi Abortion Pills Available In Sharjah Abortion Pills Available In Fujairah Abortion Pills Available In Alain Abortion Pills Available In Qatar Cytotec Available In Dubai Cytotec in Dubai Cytotec Pills Dubai Abortion Cytotec Pills In Dubai WhatsApp us at +971568316598 ///
