I bought this card for my SONY ILCE-6000.(VERSION 2.00) to use the file format XAVC S - with the Sony 32GB MS PRO-HG DUO HX High Speed Memory Stick (MSHX32B/MN). The message when XAVC S is selected says 'it does not support this memory card' etc. This item is advertised as been 50MB/s. Can I find out the true speed and why my camera is not seeing the stick for movie recording but writes photos to it OK?
bought from: vaIueTrust £45.99 Amazon
Please advise, Thanks. Alan
Hi Alan,
You need an Memory Stick XC-HG Duo or a SDXC Class 10 memory card to record XAVC S movies.
I would recommend using the second option as they're more common and not that expensive.
PD
Hi PD
Thanks for the info. I was told to record XAVC S you need a minimum of a 64GB card can you con firm?
Thanks
Alan
[Edited by moderator to remove personal details]
