I have an RDP-X30iP speaker dock and recently purchased an Apple iPod Touch 5th Generation. The RDP-X30iP is designed for the iPod 4th Generation and has a 30 pin connection. The iPod 5th Generation has a 10 pin lightning connection.
I cannot get it to function with a Lightning adapter. I have tried several different adapters. No sound comes through the dock speakers and the dock does not charge the ipod 5 with the adapter in place.
Is there a soloution?
I have same problem but also new to ipod . 1 use adaptor as a stand for ipod
2 connect to audio input on docking station via earphone using a 3.5 sterio jack to 3.5 sterio jack cable I tried this from compter as I have difficulty setting up music on ipod it works and should also work with ipod earphone connection .
3 It does not help with charging problem but you can a charger or just connect to your computer
You could do that but the iPod dock should work, it's not satisfactory that it doesn't work.
Message was edited by: voosham
