Using the S-Centre OUtput
notspurs
Will soon be purchasing the TA-AN1000 receiver. Would like to try out the sound to the tv using s-centre output.
my tv is the 75x95j. was wondering what cable do i need. I know connections are banana plugs but unsure of diameter. cannot find info anywhere.
Thanks
daveyh64
Passionné
If the correct model number of your TV is the XR-75X95J then you use the S Center synch output on the AV amp and the TVs S center synch input using a mini jack cable of suitable length for your set up, how far away is your amp going from the AV to the TV make sure length has a bit of give length wise so the connections are not strained.
So I think a 3.5mm mini jack cable connection is correct, but as you say Sony don't make looking this up easy.
Where are you buying the AV from, ask them to confirm.
7 RÉPONSES 7
profile.country.IT.title
Marino.Manolo
TV Center Speaker Mode is only for OLED TV's...
notspurs
Hi
Thanks for reply, but the tv supports acoustic center sync as it has an S-Center input and the amp has an S-Center output.
Marino.Manolo
X95J?
Marino.Manolo
You're right, forgive me, tough day today, in this case you need a 3.5mm Jack <> 3.5mm Jack cable...
It's S-Center Speaker.
Marino.Manolo
daveyh64
Passionné
notspurs
thank you both for your replies. yes, xr-75x95l. it was the 3.5mm mini audio jack info I was looking for.
Normally buy from Richer Sounds, so will ask them. In the manual, shows how to connect amp to tv using a cable,
but not what type or size of cable. I may not be correct but I think some plugs can be 4mm.
