BDP - S3100: HDMI port
SOLVED
profile.country.FI.title
rospanzera
New
Hi,
The model above has in the technical specs a HDMI (out) port. I have a TV model KDL 32W653A with an HDMI port.
Can I connect the two devices with an HDMI cable? Is it relevant that the HDMI port in the Blue Ray device is an "out" port? I suppose that's the way it should be for the connection to work, isn't it ? That is Blue Ray port = out, TV HDMI port = in...am I correct?
Thank you
Rosario
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
@rospanzera wrote:
Hi,
Thank you
Rosario
Hi there
I have looked at the Technical Specifications  and cannot find anywhere it says it has a HDMI OUT port.  If anything it will be what they call ARC (Audio Return Channel) - HDMI 1
To connect a Blu-ray player you connect it this way:
Bluray (HDMI OUT) > TV (HDMI IN)
See page 13 of the blu-ray manual here : http://pdf.crse.com/manuals/4442383412.pdf
2 REPLIES 2
Anonymous
Not applicable
@rospanzera wrote:
Hi,
Thank you
Rosario
Hi there
rospanzera
New
Hi,
thank you for your help, that is what I wanted to know.
Regards
Rosario
